cRIO PTP Synchronization with 802.3
I have tested PTP synchronization on a cRIO 9030 using "UDP IPV4", this worked very good. Now we have switched to "IEEE 802.3" transportation layer, and the PTP sync has stopped working.
Is the 802.3 supported on the cRIO? Is there any changes i need to do in order to make it work, or do we have to change back to "UDP IPV4" on the PTP-master?
Message 1 of 1
(2,582 Views)
