05-12-2008 11:02 AM
05-15-2008 02:09 PM
Massif,
If you are using LV 8.5.1 you can install NI RIO 2.4 and get calibrated values right our of you FPGA read IO node in terms of Volts/Volt
See:
http://digital.ni.com/public.nsf/allkb/C18C172029D187CA8625741600664D89
If your using the calibrated values, then you no longer need to use the LSB and Offset values. (much nicer) ![]()
