cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
cRIO CPU load is very high
we are using cRIO9024 to control many of our test rigs.
The connection disconnects when ever the cpu load is over 97% which is supposed to happen.
I just need some suggestions on how to resolve this issue or maybe if there is any additional unit that can be purchased from labview to resolve this?
Descargar todos
0 kudos
Mensaje 1 de 7
3.226 Vistas
0 kudos
Mensaje 2 de 7
3.202 Vistas
Since you did not attach your code nor even describe what the program does, how could we suggest something?
We need a lot more details.
Paolo
0 kudos
Mensaje 3 de 7
3.218 Vistas
I use labview RT.
I am running 6 different programs for different product tests at the same time.
There is nothing wrong with the programs, they are perfectly fine.
Each program controls different valves, pumps, chillers, heaters and records temperatures, pressures, water flow and various other data.
All these are causing the cpu to run at maximum capacity. I need some suggestions on how to eliminate the issue like do I have to reduce controls in the front panel or using executable could reduce the load.
Or is there any hardware that can be purchased from NI to enhance the processing.
This is more of a general question rather than a particular program issue.
0 kudos
Mensaje 4 de 7
3.207 Vistas
Optimize your routines to utilize less CPU...
Mensaje 5 de 7
3.186 Vistas
Or upgrade the cRIOs.
0 kudos
Mensaje 6 de 7
3.181 Vistas
Except that the connection is lost... Seems the exact opposite of "perfectly fine" to me.
There are more or less 50000 reasons why the CPU could be high. And probably 100000 solutions. Ranging from "put a ms wait in some loops" to "do a complete redesign".
Then it's also possible you're code is absolutely top notch, state of the art perfection, and the CPU's are simply not up to the task. That does happen.
Post the code, or we can't help.
0 kudos
Mensaje 7 de 7
3.179 Vistas
