Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
02-21-2014 08:34 PM
I have problems with the NI 9871 RS422 serial module. There is a device which has some switches on itself. device sends switches states information as a 72 byte hex character using RS422 protocol and it repeats the states information every second. Bsud rate is 115200. if there occur a state changes in switches device also send 8 byte data. I want to take this information with the NI 9871 RS422 module.
VISA Read has a byte count input and I dont know what should i prefer for the byte count. device manual says device has 64B FIFO buffer. but i can write for byte count input much more. for ex. 100, 1000 i can write this values. what is the meaning of this byte count actually. And what should i do for the RS422 read vi. should i set byte count 1 and then take all the bytes one by one? if i do that can be a problem for the speed of reading correct data. because i should use array function for the incoming data.
thanks in advance.
02-24-2014 11:02 AM
The Byte Count on VISA Read is simply the amount of Bytes that will be read each time that VISA read is called. The function might return less than the number of bytes requested if the function reaches the end of the buffer, reaches a termination character, or if a timeout occurs. The output error cluster will indicate if a timeout has occurred.
Since the state information is a 72 byte character, I would recommend reading more than 72 bytes in order to receive all the information (for example 128 bytes). If this is too slow for you, you could break it up into smaller pieces.
07-04-2014 02:07 PM
thanks in advance.
NO! you do not have "problems with the NI 9871 RS422 serial module" That hardware seems to be working fine. You have problems using it to communicate with a third party device via VISA. (Actually, I suspect you are using LabVIEW to call the VISA methods but...., that is so far removed from your real problem that it makes no difference!)
What you need to do is RTFM (Read The F$#$%G Manual) for the device that is sending the data to: understand how your program needs to interperate the data sent over the serial channel.
Posting a thread that claims a generic and unnamed "device" should be programmed in a way where "anyone" could read the mind of the developer of the firmware in the device is insane.
If Reading the device manual is difficult select a different device. (one that has a manual you CAN read) perhaps, that firmware developer was smarter than the one that wrote the com routine for your device.
And then you PM'd me? you deserve the mild chastisement. Did you READ the e-mail sent to you about how to use the forums? Hit some links near you!
07-04-2014 02:19 PM
Jeff seems to be in a bad mood today, despite it being a holiday.
What device? What is the exact protocol? If there are multiple types of messages that it can send, there is usually a byte or two telling you what type of data it is sending. You then are responsible to interpret your data correctly.
What have you tried so far? Please share some code.
07-04-2014 03:02 PM
Well not really a "bad mood" but .... When my "Droid" got reset yesterday the sound settings did not quite get reset to what I expected. so, the auto-generated email that I had recieved a PM on the forums interupted my sleep.
damned droid-
07-04-2014 03:21 PM
Jeff·Þ·Bohrer wrote: so, the auto-generated email that I had recieved a PM on the forums interupted my sleep.
Ah, so it is "cranky". My bad.
