10-23-2025 03:52 AM
I am using a cRIO-9040 running with embedded UI enabled.
The plan is to control the application from a third party touch screen.
Touch screen is connected to the display port and touch functionality works with USB.
All of this works fine, but I can not figure out how to enable an on screen keyboard in the Linux Xfce environment.
I have tried installing the "onboard" application, but I can only run the keyboard in the terminal by calling "onboard" and it closes again with the terminal.
What I need is an onboard keyboard that opens automatically when I press an I/O field in the LabView application.
I also tried using the Touchscreen Keyboard package from VIPM but this does not work on the cRIO target (ROOT dependencies are broken since some wires are not supported on the target)
Has anyone tried something like this before and are willing to share your solutions?
11-07-2025 03:54 AM
You can create a custom LabVIEW event handler that launches Onboard via a system call when a string control gets focus. For that, use the System Exec.vi to run onboard when a string control is selected.
Let me know if you need further assistance.
Kind regards,
Clara
11-10-2025 12:00 AM
Hi Clara,
Thank you for the idea!
I found a different library that implements an on-screen keyboard that is compatible with the cRIO target, so I am going with htat. But I will keep the idea in mind for another time.
