cDAQ Warning: Missing module, driver, or plugin
I have two systems with 3 LAN-connected cDAQs. On one, I have no problem in the project viewer:
In the other, I have the same driver sets installed, but I cannot access my cDAQs in the project view:
What is going on?
Dan Haugen
Certified LabVIEW Developer
CLD Instructor
(4,020 Views)
Hi Dan. What are the cDAQ chassis and/or modules you are using?
Jen P.
Applications Engineering
(3,979 Views)
They are 9135s (realtime with XNET)
Dan Haugen
CLD Instructor
(3,969 Views)
I can see that the XNET version is different.
One thing to do, is to make sure that when you install the drivers, that you remember to install support for your LabVIEW version. It's not allways that the correct LabVIEW version support is selected by default in the installation process.
(3,965 Views)
 Do you need the Real-Time module to be installed?
Try to expand the LabVIEW version, and see what modules for LabVIEW that is installed.
(3,963 Views)
