‎02-01-2018 11:02 AM
I have two systems with 3 LAN-connected cDAQs. On one, I have no problem in the project viewer:
In the other, I have the same driver sets installed, but I cannot access my cDAQs in the project view:
What is going on?
‎02-02-2018 02:46 PM
Hi Dan. What are the cDAQ chassis and/or modules you are using?
‎02-05-2018 08:03 AM
They are 9135s (realtime with XNET)
‎02-05-2018 09:25 AM
I can see that the XNET version is different.
One thing to do, is to make sure that when you install the drivers, that you remember to install support for your LabVIEW version. It's not allways that the correct LabVIEW version support is selected by default in the installation process.
‎02-05-2018 09:28 AM
Do you need the Real-Time module to be installed?
Try to expand the LabVIEW version, and see what modules for LabVIEW that is installed.
