cDAQ-9178 voltage and current same DAQmx
I am trying to make an example to test how to measure voltage and current with the above cDAQ device. Right now I do not have the HWs, but I have created a simulated device in MAX, a cDAQ-9178, with two modules: NI 9205 (voltages) and NI 9227 (currents).
I would like to also individually scale the measurements since there will be many different sensors (pressure, flow, temperature, etc...).
I made a small test VI, please find it attached. Right now just I give scaling slope value as 1, and intercept as 0.
If I test this VI only using the 2 voltage channels on the 1st module, I get simulated data from the DAQmx Read.
However, if I also include the 4 current channels beside the voltage channels, the DAQmx Read give a zero sized empty double array...
What do I do wrong? 😞
Thanks very much for help!
(3,149 Views)
Could this behaviour be a limitation of the DAQmx simulated signal? I mean, maybe it is not possible to get signal from 2 simulated cDAQ modules at the same time?...
(3,122 Views)
I suggest some error debugging (look at the error cluster).
First you will detect that DAQmx Create Scale needs an information about your current measurements (use the input pre-scaled units).
After that you need a "DAQmx timing.vi" before you start your task.
Regards, Jens
Kudos are welcome...
(3,111 Views)
I do not get any error when I run the code, neither when I stop it.
Even if I leave out the scaling part (the FOR loop with the DAQmx Create Scale.vi), the VI still does not produce data, neither any error.
In DAQmx you do not not necesserely need the "DAQmx timin.vi", specially here, where I only want to read data softwere timed (with 1 or 0.5 Hz...).
But just now, I have figured out the problem: looks like there is a bug with the simulated cDAQ module: NI 9227 (currents).
I have replaced this second module to a NI 9203 module (currents also), and my VI is just running as expected 🙂 Of course I will need to play a bit with the scalings, as much as I know, I have to give the expected min/max range (Scale min and scale max arrays) in a way so the upscaled properties fit in?
I have attached a revised version of my example VI. Please comment it...Thanks!
(3,102 Views)
