cDAQ-9174 Max Number of Modules bug?
This error occurs in NI MAX, version 16, and LabVIEW 2015.
I have four c-modules plugged into the cDAQ-9171, all of the modules are analog voltage in, for example, the 9223, 9234, 9239, and 9244 modules.
Here are the steps to recreate the error:
  1. I open MAX and see all of the modules.
  2. I click on the first module and select Test Panel and Continuous acquisition.
  3. I click on the second module and select Test Panel and Continuous acquisition.
  4. I click on the third module and select Test Panel and Continuous acquisition.
  5. When I click on the fourth module and select Test Panel and Continuous acquisition, I get Error -200022, resource requested by this task reserved by a different task.
It does not matter what order I click on the modules, whenever I get to the fourth one I get this error.
So does the cDAQ-9171 only allow 3 analog input modules? I really do not understand this error. I have tried unplugging modules, using different modules, etc. What am I missing?
Cheers,
mcduff
(3,176 Views)
Accepted by mcduff
Yes, according to datasheet you have 3 timing engines = 3 tasks with different frequency.
You can join 2 tasks for 2 modules into 1 task and sample at the same frequency.
(3,167 Views)
Thanks for clearing that up. One last question, where on the data sheet does it state this?
cheers,
mcduff
EDIT: I found it, I was looking in the manual before, not the data sheet.
Thanks again.
(3,160 Views)
It is not in 9174 specifications (https://www.ni.com/docs/en-US/bundle/cdaq-9174-specs/page/specs.html)!
It is in 917x overview, page 1:
http://www.ni.com/datasheet/pdf/en/ds-178
and in 9174 manual, page 27 Analog input
https://www.ni.com/docs/en-US/bundle/cdaq-9171-9174-9178-features/resource/372838e.pdf
(3,155 Views)
Thanks again. I need to look in the right spot next time.
Cheers,
mcduff
(3,150 Views)
