building an array with auto indexing
Hello everyone,
I have a problem and I'm hoping you can help me
Heres what I want to implement:
I have an array containing data (1d array) within a flat sequence. in the first frame I empty the array, in the 2nd I write new values into it, in the 3rd I write the values in my .csv file and then the sequence starts all over again.
so what I want to do is to create an array that adds a new row for each iteration of the sequence and save the new data in the array so I get one big array containing all the values.
I tried build array with auto indexing but I just can't seem to make it work because my input would be the value array (so only one input) and for the output i would expect an array with x rows
I'm grateful for every answer !!
Thanks, A
Message 1 of 13
(4,170 Views)
Hi AB,
so you tried something in your VI and you failed in getting the desired result: I guess the problem is in your VI and you need to debug it!
(Mind to attach your VI so we can provide more detailed answers/suggestions?)
Message 2 of 13
(4,155 Views)
Hi Gerd,
attaching a VI would be nice, but we already asked for that at LabVIEWforum.de without success.
https://www.labviewforum.de/Thread-Mittelwert-in-Excel
Regards, Jens
Kudos are welcome...
Message 3 of 13
(4,152 Views)
@JensG69 wrote:
Hi Gerd,
Regards, Jens
But most people on this forum don't speak German and would never be on the German forum to see your past message or even know it existed.  So to have success on this forum, you should attach the VI rather point to someplace else most of us can't read!
There are far more English speaking users of LabVIEW than German speakers, so I expect you'll find success here.
Message 4 of 13
(4,123 Views)
Hi RavensFan,
"ares" aka "a.b" wasn't able (or willing) to share a VI also in the German board.
We already had a long discussion without result until now…
Message 5 of 13
(4,112 Views)
@GerdW wrote:
Hi RavensFan,
Yes, it would have been nice if the OP had learned at least that (ie to share a VI) from the last discussion. Smiley Sad
Message 6 of 13
(4,105 Views)
this LabVIEW Project is confidential. I thought a forum is there to help someone and if you are not willing to help because I'm not posting the vi then don't comment and judge my decision.
I got this project few months ago and I'm a newbie in this language, also I'm just looking for an example of how to put an array like this together. I know my vi works, so no need to debug.
Regards, Ares
Message 7 of 13
(4,099 Views)
Hi a.b aka ares,
We are willing to provide help - but you aren't willing to provide an example VI demonstrating your problem!
We don't expect to share your confidential work - all we ask for (and always have been) is to provide an example VI!
Message 8 of 13
(4,086 Views)
I'm sorry for the message above, but this is what I'm trying to do but when running this vi it always overwrites the first row but what I want is that it adds another row for each iteration
Message 9 of 13
(4,084 Views)
Hi Ares,
- you are using too many local variables, use wire(s) instead
- you are using too many sequence frames, use DATAFLOW instead
- to store an array for next iteration you should use a shift register
Even now you aren't providing an example VI, all we get is an image. (These are rather hard to debug/edit with LabVIEW…)
The code in your image creates a 1D array named "Array", consisting of 10 elements, in the first frame.
In the 2nd frame you create a 2D array, with 10 rows and one element per row. This doesn't fit to your problem description!
Message 10 of 13
(4,079 Views)
