08-08-2012 04:40 AM
Hi!
I am trying to build installer for NI USB 6009 to flash LED. To my surprise the application is not flashing LED on target machine. When i test using MAX Test pannel in target machine, it is perfectly ok. The VI without build working fine. I did include LV 2011 spi1 runtime engine and daqmx core runtime. Is it logic?
Solved! Go to Solution.
08-08-2012 05:56 AM
Hi ssnp,
I would include the "full" DAQmx installer instead of the DAQmx "core".
Then I would encourage you to use "basic" DAQmx functions instead of 4 DAQ assistents. That way you would get error messages quite easily to know what happens (and why)...
08-08-2012 06:25 AM
I have included all daqmx options
Ni DAQmx applicaiton Development Support
Ni DAQmx core runtime 9,3.5
Ni DAqmx MAX configuration support 9.3.5
still the same situation.
08-09-2012 10:05 AM
hi!
My VI is working perfectly fine. When i build it and install it in host machine it is working perfectly fine . But when I install in other machine ( one i tried XP) it is not working. The MAX test panel also communicate with the relay system.
I am using lv 11 sp 1 in window 7 machine
08-09-2012 10:36 AM - edited 08-09-2012 10:38 AM
Did you actually export the hardware configuration from MAX and import it? You don't show that screen and since you are creating a task in MAX, you would obviously need that task on the new pc. The MAX test panel is not relevant in this case.
edit - you have no error handling in your VI. Pretty sure if you had done something as basic as this you would have gotten a message indicating what was wrong.
08-10-2012 04:08 AM
I am wondering do I have to export in project explorer or just adding in hardware while building is enough?
08-10-2012 03:53 PM
The hardware config is part of the installer. There is a category called Hardware Configuration. Check the box there.
08-11-2012 08:17 AM
I tried this . even export the config as ini form host and import in client. still not working
08-11-2012 06:41 PM
Did you try manually setting up max on the target to verify functionality Vs.. Verifying installer?
08-12-2012 11:01 PM
if i test using test pannel then it is working fine
