build using ni 6009
I am wondering is there any tool which conform in which stage the NI USB is giving trouble. anytool avilable.
Message 11 of 15
(913 Views)
Yes, use proper error handling as I already mentioned. That means adding an error out indicator. That's pretty basic.
Message 12 of 15
(908 Views)
Accepted by topic author ssnp
I got the impression that you were having difficulty getting the MAX configuration to install on a target machine.  So I was suggestion setting up MAX manually on the target to insure your code runs, then focus on why the MAX configuration is not installing.   Maybe I got the issue incorrect.
Mark Ramsdale
Message 13 of 15
(900 Views)
the host machine was window 7 but target machine was window xp( although it was build for it) thats why it was not running. it is fine in window 7. this will solve my problem. thanks you all for your support.
    But another question arrises why it happened.
Message 14 of 15
(883 Views)
Thanks!
Message 15 of 15
(881 Views)
