build executable problem
system: labview 5.1 on solaris2.6
At the beginning, the sources (VIs) have been developped with labview
not configured with executable option "build application".
Then, labview has been updated to be able to build executables.
No any problems when building executables for newly-created Vis (after
update)
While building execs for old VIs, error message pops up:
"Error 7 occured at Invoke Node in Dist Chg and Save
VIs.vi->Dist Build LLB Image.vi->Dist Build App
Image.vi->Build Application.vi.
Possible reasons:
LabVIEW: File not found
or
NI-488: Non-existent board"
Any ideas?
Alexandre
(3,122 Views)
Alexandre,
you may want to try and mass compile all of the vi's. If you updated labview the vi's may have to be compiled to be compatible.
pat
(3,122 Views)
Searching the NI KB at http://digital.natinst.com/public.nsf/$$Search/
will help you. Search for
(buil* OR exe* OR application)
Or search for "Error 7". There are many references to specific build
errors.
Mark
(3,122 Views)
