build array from only one condition of a case structure
Thanks for the help I've solved it now. I'm just getting use to the UI interface the logic is simple.I'm not that keen on graphical programming compared to text.
Message 11 of 12
(1,277 Views)
Then do what I do.  Although I'm a 20-year LabVIEW vet, I still write things out in pseudo-code:
WORKINGARRAY = INIT ARRAY (I32, 0)
for each Source in SOURCE ARRAY[ ]
    if Source > 5
        Append i to WORKINGARRAY
    else
        { do nothing }
    end if
end for
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 12 of 12
(1,273 Views)
