build an ellipse and plot it
Congratulations......this example is perfect!!
Thanks!
Larson
Message 11 of 21
(5,236 Views)
Great example using polar coordinates, I haven't tried that.  You can essentially mane any arbitrary polygon or shape on a coordinate system by the following steps.  Make a 2xN array (2-d example) of the polygon centered at 0,0 with an un-rotated alignment.  The number of points will determine the resolution of the shape but also the speed of the rendering.  Each point is a vertex of the polygon and is scaled from 0 to 1.0.  Then it is a simple fast group of matrix operations, consisting of rotating, scaling and then translating.  Most render engines work this way, and it is extensible to a 3-d model but will require a 3-d render viewport (an additional transformation) for viewing on an XY or picture control.  Does the polar coordinate system work with unsymetrical polygons?
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 12 of 21
(5,223 Views)
Yes!
Here's a simple modification creating a spiral instead of an ellipse (LabVIEW 7.1). 🙂
(scale of A and B is arbitrary)
Message Edited by altenbach on 09-02-2005 07:59 AM
Message 13 of 21
(5,222 Views)
hello altenbach!
Do you have some example code to build an ellipsoide (similar way to buil an ellipse example) and then plot it using a 3D plot block??
Thanks!
Larson
Message 14 of 21
(5,204 Views)
Hi Altenbach, could you save the spiral file as 7.0 please??
Message 15 of 21
(5,194 Views)
Message 16 of 21
(5,194 Views)
Altenbach's VI was great and very helpful to me.  I made a few minor modifications (Sorry its LV2012) that allow one to create error ellipses for data with correlated errors.  This is a small modification of the complex math approach of Ellipses2.vi.    This can be run in a for loop to build an array of plots, each representing an error ellipse for a single data point.
Message 17 of 21
(3,962 Views)
hi, I wish if you could help me,
I am trying to plot spiral around a specific point. actually I have line on the smith chart  connect between two complex point one of them is the minimum and the second one is the maximum. I am trying to plot that spiral around the maximum one on smithchart. I tried to use your VI  but it dosn't work with me.
could you help me to find solution for this problem.
thank you in advance .
regards
Thoalfukar
Message 18 of 21
(3,536 Views)
Please do not "hijack" a ten-year-old post.  If you have a question to ask, generate a New Message and ask your question.  It is very helpful to give your Message a good Title so people will know if they should read it or not.  If you need help with your code, be sure to attach your VIs.
Message 19 of 21
(3,509 Views)
Hi everybody,
I wish there is some one could help me to get this niRFSA working. I trying to use this VI  in my code to help me working on my computer insted of using the hardware but no way it likes dosn't work. cold any one help me.
thank you
best regards
Message 20 of 21
(3,470 Views)
