bug: data changes chanel when I export
Yes,The data after use decimate function is correct but  channel is shift.
And Here is 3 channels data,So I will try your solution and will tell you a result.
Thanks you so much
Message 11 of 16
(987 Views)
I already tried your solution,It seems does not work.The output data is no correct and also still channel shift.
Message 12 of 16
(953 Views)
Hi Mindgats,
So it seems that the data itself from your prior conversations. The problem is that it is still storing data as A,B,C,A,B,C…. where A is Ch0, B is Ch1 and C is Ch2. Is this right?
How are you configuring the Write to Measurement File and the Convert to Dynamic Data function? Could you post an image of how is the data organized in the output of the second Build Array?
Message 13 of 16
(927 Views)
Hi,amezam
Yes,You are right.I covert from 1D array to Dynamic data.
Last week I found that if I adjust number of elements to 3000 and AI sampling period(us) to  1000,The system will have 1k Hz for sampling rate and The channel shift is not happen but when I use higher smapling rate the channel will shift again but some times It's not happen, I don't know why.
ps. I export file by use binary TDM data type
       I have to use high sampling rate to measure signal
Message 14 of 16
(911 Views)
It's is data that i use high sampling rate(100k Hz),Channel change just one time in number 3499.
Thanls for reply.
Message 15 of 16
(886 Views)
Hi mindgats,
When interleaving multichannel data, you must specify that the number of elements to write to the buffer is an integer multiple of the number of channels. This ensures you can read the same amount of data from each channel in the RT side. Make sure the Convert from Dynamic Data is set to 2D array of scalars – rows are channels.
Message 16 of 16
(863 Views)
