04-10-2008 09:36 AM
04-10-2008 09:46 AM
04-10-2008 09:58 AM - edited 04-10-2008 10:01 AM
04-10-2008 10:06 AM
04-10-2008 11:24 AM
04-10-2008 11:45 AM
04-10-2008 11:53 AM
At the very beggining top left of your VI you call DAQmx Timing and set everything...in the "Samples Per Channel" input, right next to "Sample Mode" (that you have continuos wired into wire a constant with a 1M value. That will set the buffer to max size.
04-11-2008 04:02 AM
04-14-2008 09:56 AM - edited 04-14-2008 09:57 AM
04-15-2008 09:41 AM
Hi all!
Sorry for jumping into your conversation but I experience a similar problem as SergueiK and after reading a lot of forum messages concerning this topic I thought maybe I can profit from your experience since I'm quite new to Labview.
to the problem:
I wrote a simple 1 to 3-channel (optional) acquisition .vi (see attached). For low acq-rates (till 10KHz) the continuous acq. works fine. But when I mount up to 80k - which is necessary for my experiment - I soon get the FIFO-buffer-overflow error message. I tried to raise the buffer size by setting a high number of samples per channel (p.ex: 240k) but this slows Labview that much, that the vi is not able anymore to stop after the set recording time (up to several seconds later, if not even creating another buffer overflow).
I'm afraid that some poor programming from my side might be the main reason for this situation so I would be most thankful if you could give me some hints how to ameliorate.
Thanks in advance
Bernhard
my system: DualcoreIntel 2.13GHz, 2Gigs RAM, WindowsXP prof., LabView 8.20 basic license, PCI-6259 with BNC2090A
