02-23-2017 10:13 AM
i want to put on/off Boolean lights in an array and when another ok button is pressed an additional light is added to the bottom of the array, please help! I used a loop but I also can't turn them on and off for some reason.
02-23-2017 10:22 AM
How can we help if you don't show us what you've done so far?
Please attach your VI.
02-23-2017 10:24 AM
this is the output
02-23-2017 10:31 AM
That is not a VI.
That is a blurry Jpeg picture of a front panel. It doesn't help us help you.
02-24-2017 12:19 AM
I've quickly build this VI (this is one way of doing it).
You can check if that's what you need.
02-24-2017 01:38 AM
EliasN wrote:I've quickly build this VI (this is one way of doing it).
02-24-2017 01:51 AM
As said earlier, you probably want to use an array of fixed size in a shift register. and change elements from false to true in order. Do you know what a shift register is?
From the above, you seem to use an array indicator. Compared to a control, an indicator cannot be operated directly at run-time. If you want to also be able to operate the array elements directly, you need to make it a control. In this case you would need a local variable to do programmatic value changes.
If you don't understand what I am saying, you need to start with a few basic LabVIEW tutorials. If you would post your VI, we will help you make it work and give more specific advice.
