bool to numeric
Hello everyone,
I'm currently tring to make a LED lamp blink in 5 different freqencies due to differenceses in voltage. I have made the 5 differnet cases for 0-1, 1-2 , 2-3, 3-4, and 4-5
Is there any smart way to make the program decide which case to run. I hvae 5 boolean values to select the 5 different cases.
Message 1 of 10
(12,097 Views)
Accepted by m3gney
Use the Boolean Array to Number.  Right click the case structure and change the radix to binary.  Binary will probably make it easier to understand which case is which.
aputman
Message 2 of 10
(12,084 Views)
Message 3 of 10
(12,082 Views)
I like this solution
decode bool array
Instead of the attached VI you could use the Search 1D Array- function from the array palette.
It is important to say, that the enum has to be typed to U32 for the typecast to work!
Greets, Dave
Message 4 of 10
(12,065 Views)
Since it is not possible to attach a vi due to weird type mismatch of application/octet-stream I insert it as a snippet:
Greets, Dave
Message 5 of 10
(12,056 Views)
Hello m3gney.
You should better use an Array than several bolean displays. As the blincking frequency couldn't be the same as the acquisition frequency, you shouldn't do it in the same process.
The idea could be to create two loop, one for the acquisition and one for the blincking led.
I made you a VI
Good luck.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
Message 6 of 10
(12,041 Views)
Put your 5 buttons in a Radio Buttons cluster, then just wire its terminal to the case selector.
Message 7 of 10
(12,007 Views)
Thanks a lot for all the great help! I managed to fix the case structure, but now I have a new problem. I'm getting two different error messages
Error (-201003) and (-200279) and I have no clue how to solve it. The rest of the errormessage (-200279) is below the picture.
Possible reason(s):
The application is not able to keep up with the hardware acquisition.
Increasing the buffer size, reading the data more frequently, or specifying a fixed number of samples to read instead of reading all available samples might correct the problem.
Property: RelativeTo
Corresponding Value: Current Read Position
Property: Offset
Corresponding Value: 0
Task Name: MyVoltageTask
Again, thanks a lot for all the help.
Message 8 of 10
(11,934 Views)
You should start a new thread since this is another topic. This will increase the chance to get appropriate help.
Greets, Dave
Message 9 of 10
(11,919 Views)
Will do.
Thanks for all the help! Smiley Very Happy
Message 10 of 10
(11,909 Views)
