取消
显示结果
搜索替代
您的意思是:
bluetooth error 56
已解决!
转到解答
hello everyone,
i try to communicate with arduino via hc06 device and i get error code 56,why?
i attached the vi file
thank you,
0 项奖励
1 条消息(共 7 条)
4,314 次查看
thank you,
First couple questions here...
  1. Do you have one or two BT modules?
  2. Are the BT modules paired?
  3. Are the communication parameters setup properly on both modules?
=== Engineer Ambiguously ===
0 项奖励
2 条消息(共 7 条)
4,291 次查看
I don't think you understand how to use these modules. There is no reason to use the LabVIEW bluetooth vi's as the HC-06 (and HC-05) are in essence "smart modules" .
You use a terminal emulator like Terra-Term to setup the module operation mode (master/slave), pairing, pin, communication settings, etc. then pair it to your computers built-in BT . Then once they are paired your computer should add a virtual serial port that corresponds to the HC-06.
The HC-06 is now "transparent" to the Adruino and computer you connect to it using a com port, VISA serial, VISA Read and VISA Write, just like any serial device.
https://www.itead.cc/wiki/Serial_Port_Bluetooth_Module_(Master/Slave)_:_HC-05
https://www.itead.cc/wiki/Serial_Port_Bluetooth_Module_(Slave):_HC-06
0 项奖励
3 条消息(共 7 条)
4,274 次查看
sorry but maybe the explain was bad ,i want to use the pc bluetooth device to comunicate with hc06 device that connected to the arduino.
i paired the device to the pc.
when i try to read/write from or to the device i get error code 56.
0 项奖励
4 条消息(共 7 条)
4,258 次查看
thank you,
1.pc bluetooth device and hc06 device/
2.yes.
3.9600 baud rate in the two devices.
0 项奖励
5 条消息(共 7 条)
4,257 次查看
解答
已被主题作者 pizioglove 接受
Well like I said these devices are basically transparent, you do not need to use any of the LabVIEW Bluetooth vi's because Windows takes care of all that low level BT stuff when you pair the device
Once the HC-06 is paired to your computer you should see a Comm port that corresponds to the HC-06.  You should still be able to use the Arduino IDE just like if you were plugged in using a USB cable
With LabVIEW you communicate with the Arduino using VISA just like any other serial device or LINX.
0 项奖励
6 条消息(共 7 条)
4,242 次查看
Zillabob is correct,there is no need for the LabVIEW bluetooth vi's just use VISA or LINX once you have the HC-06 paired with your computer.
0 项奖励
7 条消息(共 7 条)
4,236 次查看
