**bleep** you, error 1502!!! (shakes fist)
Great! it works very well. In labview2020, it also great.
Message 41 of 47
(1,274 Views)
I have encountered this error 1502 recently in Labview 2020 64 bit, when compiling an .exe via application builder.
I was able to resolve error 1504 by making a copy of the affected build-specification und than run the duplicated build.
Message 42 of 47
(1,264 Views)
great. it seems like a labview bug.
Message 43 of 47
(1,245 Views)
Clean the build! Just select the build spec, right click and select Clean Build. Then rebuild the build.  Always works.
"Should be" isn't "Is" -Jay
Message 44 of 47
(1,230 Views)
this method is not working. Still error 1502
Message 45 of 47
(1,185 Views)
Well then we can only guess unless you zip the project.
Guessing, the only other time I have seen a 1502 from a cleaned build spec is when builds are built in the wrong order e.g. pressing build all with a ppl /dll spec below an exe or building the installer before the exe.
 Or building the exe/installer from separated code without a cleaning the source distribution first then building the exe from the distro.
That is, you are doing something wrong but, it's a workflow problem not a bug per se.
Message 46 of 47
(1,170 Views)
anyway, i find the method solve my problem. It's better than "check the debug model"
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P826SAC&l=zh-CN
Message 47 of 47
(1,164 Views)
