biomedical toolkit WFDB
Hi all,
I'm recording a set of biomedical signals using Labview 2013. I also have the biomedical toolkit installed. In the description of the toolkit available online https://www.ni.com/en/support/downloads/tools-network/download.labview-biomedical-toolkit.html it's written that it is possible to covert files to WFDB format through the Biomedical Workbech.
Do you know if the conversion function is also available in Labview? I would like to save or, at least, convert my biomedical signals to WFDB directly from my labview VI.
Thanks for the help.
(3,107 Views)
I don't understand. You say you have the toolkit for LabVIEW installed then ask if you can use it in LabVIEW.
In any case, that paper has a link regarding questions about the toolkit and another link to a special forum for the toolkit. Have you used either of those links. They would be more appropriate than here.
(3,089 Views)
you can also check this and this.
I hope this helps.
Bye,
Licia
(3,058 Views)
