binary bit operation
I just met a problem with 9-digits in binary bit operation.
Long time ago, I manipulated some binary and remembered that the first digit could be considered as significant or other specical meaning.
Though I guess the solution as the attachment, I would like to know the right technique in binary operation.
1) How can I replace the FOR loop with a simple bit operator?
2) I am trying to use U16 (16 bit) to adopt all  nine digits but how to remove the first digit or some digits in sequence as a final data? (In my code, I just substract a number from the calculated number.)
for example, (1)101000111 ->101000111 or (11)01000111 ->01000111
3) In other curious question, the lower three digits (111) is fixed in my application.
How can I separate or add the digit in calculation for simplicity?
for example, 110100(high)+(or some operation)111(lower)=110100111
labmaster.
code: LabVIEW 2014.
(8,539 Views)
Hi master,
1) (1)101000111 ->101000111 or (11)01000111 ->01000111
1xyzb AND 0111b = 0xyzb
2) 110100(high)+(or some operation)111(lower)=110100111
xyzb * 1000b + 0111b = xyz111b
("b" marks binary numbers)
(8,521 Views)
Thanks!. I forgot digital operation at all.
I revised my posting. Can you review my question again?
(8,516 Views)
Accepted by labmaster
I typically use an AND to mask off the bits I do not care about.
That is typically done with some interesting masking (with the AND) or setting of bits (with the OR) and the Logical Shift.
(8,504 Views)
Hi master,
instead of adding a number 45 times you can also multiply that number by 45 before adding:
Hint: Always make the radix visible when you use non-decimal numbers!
(8,501 Views)
Thanks for your additional comments.
if x=3 (decimal), y=00010 (binary)
if x=64, y=11111
There is an offset (-1 in decimal) for simple equation.
The problem to me is how to treat the most significant digit.
How can you set up a formula using the bit shift or boolean operation without any numerical operator?
labmaster.
(8,483 Views)
Hi master,
What exactly is the problem?
Do you have specifications/requirement on how to handle the MSB? Then apply them!
(If needed you apply your rules to each mathematical operation!)
Why do you want to have mathematical operations without using mathematical operators?
It seems to me you are talking about "saturated arithmetic" (see Wikipedia). Can you describe the algorithm you want to program?
(8,472 Views)
