benchmark
Hello all,
I was trying to make my own "benchmarking program"
too see if my code can become faster.
I already a vi for it, see attachment.
The strange part is that it gives 0.0000000000 for the following program:
Is there a problem in my code?
Or is my pc too fast Smiley Very Happy
Koen
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 1 of 11
(5,224 Views)
Your attachment and VI doesn't match
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 11
(5,221 Views)
The vi is the benchmarking vi that i made.
the picture that i delivered was just a way to test if it worked, the tested vi has no purpose.
Message 3 of 11
(5,215 Views)
where you receiving 0.000000?
--Ranjeet
Message 4 of 11
(5,212 Views)
which is following vi
--Ranjeet
Message 5 of 11
(5,209 Views)
Yes, I was receiving that over the flat sequence. As elapsed time.
Here is the test vi
Message 6 of 11
(5,207 Views)
You have to temporize your loop. Otherwise you are collapsing your computer processor.
Message 7 of 11
(5,200 Views)
Thats actually what I'm trying to do. To see how fast it can run.
Though I don't like the ms counter i made my own counter (benchmark.vi).
The problem is when I wire it in a flat sequence it will give 0.000000 when they are substracted
Message 8 of 11
(5,194 Views)
Accepted by KoenR94
I think that it is too fast, just try it:
Message 9 of 11
(5,186 Views)
Yes you were right. The loop was just faster then 0.0000000000s
increased the iterations to 8000000, and it gave an answer:0.0312504768371582031s
Message 10 of 11
(5,174 Views)
