basic Labview question
hi
I use labview 8.6.1
When I try to use the formula node, even with a very simple formula /:
x^3-x^2+5
when x equals 10 , it gives me the output of -6.1..
but it should be 905,
and some times it gives me an error of integer type required: e.g: y=x^3,when th input is 10.
Message 1 of 8
(5,163 Views)
If you use the correct syntax for exponentiation, it works just fine. You must use '**'. This is documented in the help.
Message 2 of 8
(5,158 Views)
I ran into that exact same problem earlier.
Contrary to any intuition, the ^ operator does not mean exponent, it means bit XOR.
The operator you should use is **
Try this expression:
x**3 - x**2 + 5
Cory K
Message 3 of 8
(5,156 Views)
In the formula node you need to use ** to indicate power. This is documented in the LabVIEW Help.
Any reason you're using the formula node as opposed to using straight G?
Message 4 of 8
(5,153 Views)
I see everybody is picking at the low-hanging fruit. Smiley Very Happy
Message 5 of 8
(5,150 Views)
Instead of using the carat to raise a variable to a power, you will want to use the double asterisk that is documented in the LabVIEW help. Try using x**3-x**2+5 and you will get the answer you are looking for.
Message 6 of 8
(5,134 Views)
Accepted by sh3333
Its a Monday Smiley Tongue
Cory K
Message 7 of 8
(5,132 Views)
Maybe a monday but definetly not the solution...:smileyvery-happy:
Message 8 of 8
(5,038 Views)
