backup and restore files
Hello everyone,
I have a set of production machines which are connected to a LAN. All the machines have a local hard drive on board. Periodically (eg once a week), I back up (copy and paste on a network drive) their configuration files, which can be accessed by a PC on the same LAN.
In case, I may need to restore a configuration file, that is to select one file from the network drive and copy it on one of the production machines.
Can all this be programmed semi-automatically using Labview? If yes (and I assume so) is there any example available which you can provide? Thanks
(3,276 Views)
The answer is "Yes"
But further questions begin.
Are local drives is network published?
If so, then you just need a program that reads files from these disks and saves them to its local disk.
If not, you will likely need clients on each machine and a shared server.
Clients will send these files to the server, which will keep all files in local drive. And if necessary, send back.
(3,263 Views)
In most cases, yes (I will eventually address other cases separately).
I knew it could be done, but I cannot figure out how. Is there an example to draw from?
(3,258 Views)
Accepted by topic author DavideB
I am puzzled.
Do you need an example of copying a file?
(3,254 Views)
