autosave in pdf and autoprint
I downloaded a pdf printer
and used the active x code above to  print front panel
the code print panel to printer,
i see the pdf printer as my default printer.
i used PDFCreator-0_9_7_setup.exe
i think you can google that
the latest version would work too i believe. i just happened to use that version at that time.
Install PDF Creator
PDF Creator is a free tool to create PDF files from nearly any Windows application.
PDF files are for long term archives of test results data.
1. Install media, locate the file “PDFCreator-0_9_7_setup.exe” and double click to install the software.
Follow the prompted
instructions.
2. Click Finish. The installation is now complete.
3. To configure the PDF Creator setting
a. On Windows XP, click Start, click Programs, click PDFCreator, and click
PDFCreator.
Message 11 of 12
(996 Views)
you can plot and do things on excel so that you can look at the data another time.
printing front panel will only let you view the data but you cant munulipate it in excel later.
let me know if you need help with that.
Message 12 of 12
(992 Views)
