‎02-27-2012 06:07 AM
I am designing an user authentication page where there are two string controls and 3 boolean controls. At the time of run, I am giving input to one string control, then by tabbing, going to the next string control. Then if I press TAB it is going to one of the boolean control. But I want to select one particular boolean after giving the string to the second string control, and when I shall press enter, that particular boolean will be on. I have tried to do anything in the 'Key navigation' in 'Properties' of the boolean control. But there is no such option. Please help me to do it.
‎02-27-2012 06:14 AM
If you want to control a boolen by pressing enter key you can select Key Navigation>Toggle>Return. Then whenever you press Enter your boolean will be triggered ON.
‎02-27-2012 06:59 AM
You need to se tthe tab order. See below:
‎02-27-2012 10:29 PM
Thanks to aeastet and P Anand both. I have solved my problem with the help of the suggestions that both of you have given. Thanks a lot to help me.
