autoadjust scale limit on plot, with offset
I have a plot and the y scale is set to be scaled automatically. This is what I want. However, the space between the current highest value of the graph being plotted and the current highest value on the y scale is too small. Is there away to give it an offset?
For example, if a constant value of 17.8 is being plotted, the highest value shown on the y scale will be 18. Could I force it to be, say, 20?  that would be 20 - 17.8 = 2.2
So for example, can I set a permanent offset of 2.2 for this separation?
I hope this is not too confusing... Thanks!
(3,004 Views)
You can do whatever you want. Simply disable autoscaling, then set your own Ymin and Ymax via a property node.
You can calculate the desired values from your data e.g. by using "array min&max" and adding the extra padding.
(2,995 Views)
Sure. First, check to see if Loose Fit is checked for the Y axis (right click on graph, Y Scale>Loose Fit). With this checked, it might be enough for your needs. Otherwise, you can use a property node to autoscale the Y axis once, then get the YScale.Maximum, add your offset, and write it to YScale.Maximum.
Message Edited by Dennis Knutson on 03-30-200609:23 AM
(2,995 Views)
