auto-populating folders and .lvclass files
@tst wrote:
I'm not aware of anything like that. I certainly don't see how it would relate to DD VIs. What I did want to add in my last reply (and probably forgot) is that auto-pop. doesn't make much sense in libraries - libraries define membership strictly, so you have to explicitly add the VI to the library (and it presumably can't be both in the library and in the auto-pop. folder at the same time, but that's just a guess. Maybe that's the issue he was talking about). In short, if you have a library (and a class is a library), you don't need auto-pop., because all the VIs in the library appear in the project.
Your explanation of why auto-pop and libraries makes a lot of sense, and it also helps me better understand Aristos Queue's response on this thread. I think you are right that the apps engineer might have been refering to the fact that the file can't be in both the auto-pop folder and the library (class) at the same time, so a "copy" is made somewhere, somehow.
Message 11 of 11
(804 Views)
