Menu Ring with Case Structure Help
I am working on a labview project where I want the option to view two different panels using a menu ring (so if I select "Standard Configuration" it shows me one configuration of the data and if I choose "Delta Configuration", it shows me another configuration of the data. Currently, I have the menu ring set up so it is connected to the '?' terminal of a big case structure with 2 cases "standard configuration" and "delta configuration"- however, when I look at the front panel, everything from both cases is clumped together and when I select which configuration I want in the front panel, it doesnt change anything. Is there any way to split up the graph/numeric indicators so that they are only present in their respective configurations?
Thanks!
(4,402 Views)
I can already feel the leering eyes from some people here, but why don't you just use a Tab control?  Then your user just chooses which page is visible.
(4,398 Views)
Tab control is the simple, less flexible answer (and there's nothing wrong with that!).
The more advanced (but significantly harder to implement) answer is to use a Subpanel - you load different VIs into the subpanel depending on the selection from the menu. You will have to implement some sort of communication between the SubVIs and your main configuration page as well as dealing with loading the VIs into/out of the Subpanel. It's how things like the LabVIEW configuration dialogues work, though.
(blog)
(4,386 Views)
