auto expand
I just installed LV for Vista and I notice the behavior was different from XP.  How do you guys force the palettes to always expand instead of clicking on it everytime?  I kept looking in the option but it was no where to be found.  Thnx
Message Edited by lavalava on 11-08-2009 10:43 AM
(3,410 Views)
Accepted by topic author lavalava
With the palette you see, click on the View button,  then change visible categories.  Then Select All.
I believe this is what I had to do when I saw the same short menu that you are seeing now.  I find there are a few other palette settings I had to change as well to go from whatever is the new default that LabVIEW uses to the palette format I'm used to seeing.
(3,395 Views)
I agree- the "new" default settings speed up launching LabVIEW but I've found that, for myself, Its worth the start-up time hit to load the palattes during launch so they are available the first time I want them.  It too bad the palatte "View" menu is only avalable from "View>Control palatte" or "View>Functions Palatte."  I would expect the old right-click on FP ar BD to offer the same View.
"Should be" isn't "Is" -Jay
(3,381 Views)
Thanks guy.  I've found it.  To do so I had to pin it and select View -> Change Visible Categories -> Select All.  LV is one of those things I don't think I'll ever learn them all.  It seems like there way too many unexplore territories Smiley Wink
(3,366 Views)
