asked to choose library when starting labview program?
I am trying to move a labview program that I created to another computer. I installed labview on the new computer, but when I open my program first it asks me to choose a library, which it has never done before. Then the program won't work--there are all sorts of errors with polymorphic vi's, etc. I've tried re-installing Labview, but it doesn't change anything. Could it be the way I'm saving my program? Any suggestions?
(2,780 Views)
What is the library that it's asking for? Were you using any add-ons on your other computer that you just didn't install on the new one?
(2,776 Views)
I wish I knew what library it was asking for, it just says "choose library" when the program is loading. I didn't have any add-on's either. I've attached the file if that helps at all.
(2,775 Views)
I was able to open the VI but am missing 2 sub VIs: Write String to Spreadsheet.vi, which I just replaced with my copy of that VI, and then there's Diff-Array.vi. Maybe post a screenshot of that error?
(2,770 Views)
