arrow key function in front panel
All the Verrrrrrrrrrrrrrryyyyyyyyyyyyyyyyyy best.
You will find me on forum
Somil Gautam
Think Weird
Message 41 of 67
(2,612 Views)
Hi Titano,
The official way to thank someone on this forum is to click on the Kudos star. The total count of Kuods helps contributors earn "atta-boys" and climb through ranks. So I'd like to invite you to go back through this thread and mark up Somil's posts.
Thank you!
Ben
Message 42 of 67
(2,606 Views)
Thanks Ben
I hope Titano reads your postSmiley HappySmiley Happy
Somil Gautam
Think Weird
Message 43 of 67
(2,598 Views)
Hi Somil and Ben
Have kudos to the thread. Hope it increases Somil's rank.
And Somil, I will be back to bug ya agn soon.
Thx N Rdgs
Titano
Message 44 of 67
(2,591 Views)
Thanks Titano
i will be waiting for you  🙂
Somil Gautam
Think Weird
Message 45 of 67
(2,589 Views)
Hi Somil,
I've attached a VI. I'm finding difficulties to do some changes to it.
The concern>>
1. I want to the edit the numeric controls into boolean increas and decrease buttons.
    Meaning, I do want to manually clcik the radix to input values.
    Instead, for every axis, have 1 increase and decrease button and the value is reflected in the numeric control.
I need ur expertise in this. Pls do help.
Thks N Rdgs
Titano
Message 46 of 67
(2,583 Views)
See, you have increment/decrement button also along with the numeric control. is that not serving your purpose?
Somil Gautam
Think Weird
Message 47 of 67
(2,579 Views)
Hi Somil,
I do not want the increase/decreas button. Instead have boolean to do the function.
For better front panel usage and appearance.
Thks N Rdgs
Titano
Message 48 of 67
(2,576 Views)
Ok. you want separate buttons (increase and decrease) instead of the numeric control
then use the VI which i posted yesterday or you still want something else?
Somil Gautam
Think Weird
Message 49 of 67
(2,563 Views)
Hi Somil,
oh K.. I shall try that first.
And 1 more important thing.
The needle's movement's speed is variable meaning it can be chosen from a given set of values.
But I can only show it in terms of time delay in my case.
I could not find any XYZ plot in LabVIEW for me to simulate these effects.
I can only show it in XY which is inadequate. I've attached  a VI to illustrate that.
I'm also wondering how to input these set of speed values in conjunction with my movement Vi.
Meaning, the operation is such:
1. First the appropriate speed is chosen say speed 1 out of 5 kinds of speed.
2. Then the increase and decease buttons are pressed, moving at the chosen speed.
3. Finally numeric controls to reflect the movement coordinates.
I am clueless of how to combine these 3 functions together.
PLs advice.
Thks N Rdgs
Titano
Message 50 of 67
(2,559 Views)
