arrow key function in front panel
Hi guys,
I want to have a arrow key in the front panel to control the running of a number.
Meaning;
If i press the left arrow key, the number decreases and the right arrow key, the opposite happens.
I found a arrow design under decorations but unable to edit anything with it.
Basically, the arrow key just have to act like a boolean switch.
Once pressed, it lights up and the number runs accordingly and stops when let go.
I want to have the arrow keys to make the front panel look more presentable.
Pls do advice me.
PLs Note: I'm not using the keyboard to simulate on the front panel. It's purely on front panel.
Thks N Rdgs
Titano
Message 1 of 67
(7,541 Views)
So the "arrow keys" you are talking about aren't the arrow keys on the keyboard, but boolean buttons on the front panel?  Then obviously you'll use boolean buttons.  If you want the arrow to appear on them, then you will need to customize the boolean button and apply the arrow image to the button
Set up the button action to be "switched while pressed".  If the "left" button is true, then decrement your counter.  If the "right" button is true, the increment your counter.  You'll probably have to play with the speed of your while loop so that the counter changes at the speed you want.  That counter then just feeds an indicator inside the loop.
Message 2 of 67
(7,532 Views)
Thx for the reply.
I am using boolean switches. BUt I cant seem to customize them.
As per ur reply, I need to import arrow images and place them into the front panel.
HOw about the arrow lighting up when pressed?
Do i probably have to serach for .gif images and place them into the front panel?
PLs advice.
Thks N Rdgs
Titano
Message 3 of 67
(7,529 Views)
see this.
customize the buttons
Somil Gautam
Think Weird
Message 4 of 67
(7,522 Views)
Hi Somil,
Thx for ur reply.
Actually I'm facing difficulties customiizing a button of my preference to act as a boolean switch.
I'm having this particular arrow.jpg imported into my front panel.
Now my concerns for this arrow,
1. How to make it work like a boolean switch?
    1.1 It lights up when pressed ,runs the command appropriately and does vice versa when let go.
I've attached a sample arrow .jpg.
Thx N Rdgs
Titano
Message 5 of 67
(7,515 Views)
Sori, the arrow  image is attched here.
Message 6 of 67
(7,512 Views)
i guess you forgot to attach the jpg
Somil Gautam
Think Weird
Message 7 of 67
(7,511 Views)
Hi Somil,
I 've attached  a pic of how i want my arrows to be on the front panel.
Pls do take a look.
Thks N Rdgs
Message 8 of 67
(7,505 Views)
Accepted by Titano
one thing you can do. i should work
1. right click the increase button in the VI and select advanced>>customize
2. next a window appears where you can customize the button.
3. right click the button and select import a picture from clipboard>>decal
4. this should look like this (attached)
Somil Gautam
Think Weird
Message 9 of 67
(7,501 Views)
i should work
it should workSmiley Wink
Somil Gautam
Think Weird
Message 10 of 67
(7,499 Views)
