arreglo
Estimados señores:
Escribo por lo siguiente, necesito hacer la siguiente operación con un arreglo, pero he probado de distintas maneras, por horas y no consigo dar con la manera de hacerlo; puede ser fácil, pero no me resulta.
La idea es la siguiente:  si el arreglo original es (a, b, c, d, e, f,g,...), en donde cada elemento es un número real, necesito obtener
(a, a+b, a+b+c, a+b+c+d, a+b+c+d+e,a+b+c+d+e+f,a+b+c+d+e+f+g,a+b+c+d+e+f+g+...,....), es decir, simplemente cada término corresponde a la suma de los anteriores.
Si alguien me puede ayudar, se lo agradeceré.
Message Edited by fgarcia on 01-20-2010 11:37 PM
Message 1 of 19
(4,309 Views)
Try posting in english here for better response
translation from spanish
I write about the following, I need to do the following operation with a settlement, but I tried in various ways, for hours and I can not come up with a way to do it can be easy, but do not find it.
The idea is this: if the original array is (a, b, c, d, e, f, g ,...), where each element is a real number, I need to get
(a, a + b, a + b + c, a + b + c + d, a + b + c + d + e, a + b + c + d + e + f, a + b + c + d + e + f + g, a + b + c + d + e + f + g +...,....), ie each term simply represents the sum of the above.
Message 2 of 19
(4,296 Views)
Message 3 of 19
(4,294 Views)
Accepted by topic author fgarcia
Muks,
Why wouldn't you autoindex the incoming array?  Smiley Wink
Message Edited by Ravens Fan on 01-21-2010 01:27 AM
Message 4 of 19
(4,286 Views)
oops you are right. Thanks for correcting it.........:smileywink:
Message 5 of 19
(4,283 Views)
Hi muks,
U r such a brillaint guy to provide solutions for complex requiremnts too.. appreciate your diligence in translating the spanish content.. i am a follower of this forum.. u r my icon..
Message 6 of 19
(4,278 Views)
I hounoured. Thanks mate. But i feel i am still very much learning labVIEW....:smileywink:
Message 7 of 19
(4,271 Views)
Smiley Very Happy
 by the way where do u work and where are you put up?
Message 8 of 19
(4,256 Views)
Message 9 of 19
(4,243 Views)
oh is it i am also from ilink only.. hmm good to know that... Smiley Surprised
Message 10 of 19
(4,224 Views)
