User-Interface tab control question
Heey everyone,
I`ve disigned a program and a user interface, on this user interface there is a tab control (see attachement) in this tab control you can select several measurements. This is a school project and according to my teacher it isn`t clear enough which measurement is chosen.
My question: Is there a way to give the active tab a different color? If not then do you know a way to create a nice user-interface which has the same abilities as the tab control (select measurement and fil in values for the measurement).
Thank you
Currently using labview 8.2.1
(3,386 Views)
Accepted by topic author Grasman
Hi Grasman,
it is possible to give different Tabs different colors, first you should activate Multiple colors - "Right-click on a tab on the control. Select Advanced » Allow Multiple Colors.
To change only the color of the active tab, please see Steve Birds VI, you can find this on the following forum post
Active Tab Color
Tobias
(3,375 Views)
thanks TobiD! both solutions work great, i`ll kudo youSmiley Tongue
(3,364 Views)
