arrays
Hii In labview, there are datatype U8, U16, Int16, Int32 etc... I want to creat an array where each element in array is 1bit or 2bit or 3 bit....
how do this... and how to dispay an image of 2bit or 3bit...
Please let me know
Prashh
Message 1 of 10
(4,454 Views)
Hi, Prashh,
Theoretically you can create array of clusters with booleans (one, or two or three for different bit depth.)
But for achieving best performance, I would like to recommend to use U8 type where only 1 or 2 or 3 bits are used.
For displaying the image you can use Binary Palette, for example, for 1 bit image - with black (zero) and red (1). For two bits you may have only 4 different colors, and so on.
Andrey.
Message 2 of 10
(4,444 Views)
Hello andrey
     Thanks for ur reply. How can I create 2 or 3 bit image with boolean pallete...
Can u pls send an example for creating and displaying an image of  3 bit...
Prashh
Message 3 of 10
(4,428 Views)
Seems like the most direct way of displaying the array and getting the "bits" out of it would be a 2-D array of buttons....
Message Edited by Broken Arrow on 10-09-2009 09:23 AM
Richard
Message 4 of 10
(4,407 Views)
prashiit wrote:
Hello andrey
Hi, Prashh,
I hope, the code given below will explain something:
Not really Andy Warhol artwork, but something similar:
best regards,
Andrey.
Message Edited by Andrey Dmitriev on 10-10-2009 11:35 PM
Message 5 of 10
(4,366 Views)
Hello Andrey,
    I am using 8.6 version. Please send me 8.6 VI
Message 6 of 10
(4,346 Views)
The Block Diagram is so trivial, you can recreate it in 10 min by provided screenshot... 8.6 in attachment.
Message 7 of 10
(4,340 Views)
Hello Andrey
   Thanks for your VI. But, I want to use it for gray scale image.
for example: If I put 0 shift, Image should be displayed with 256 different gray levels.
                                -1-------------------------------------- 128------------------
                                -2---------------------------------------  64-------------------
-3---------------------------------------- 32-----------------
-4---------------------------------------   16-------------------
Message 8 of 10
(4,319 Views)
As you can see in the example above - IT IS grayscale image, just displayed with pseudocolors. Just change 4 colors palette to 4 shades of gray and you will get what you wanted.
Message 9 of 10
(4,309 Views)
to Broken Arrow: please read this: WARNING: Don't clean out your image gallery!
Message 10 of 10
(4,301 Views)
