arrays as decision making
hi,
i have a list of arrays which need to be use as input to decision making. attached are the VI and input file. When high_data is >10, it must perform the squareroot which is under the True condition. When the high_data is less than 10, it should return zero whcih is under False condition. i tried to use case selector but it seems array cannot be use for case selection. Can anyone help me with this. Thanks
(2,868 Views)
Accepted by topic author varsha88
First of all, you have race condition due to the blatant overuse of a local variable. Most likely, the local variable gets read before the terminal of the array gets valid data. Remove the local variable and use a wire directly. Remember, LabVIEW does not execut top to bottom or left to right. Execution order is fully determined by dataflow alone. If you have several CPU cores (and you probably have), things can even execut in parallel.
Second, have you tried to simply wrap an autoindexing FOR lop around the case structure? Then clean up the false case, which needs a scalar instead of an array, etc.. There are also loop-free solutions to this, but let's stick to the basics.
(2,856 Views)
hi altenbach,
I do not really understand how to do the "wrap an autoindexing FOR lop around the case structure? Then clean up the false case, which needs a scalar instead of an array" because im still new to labview. can you share the vi? thanks
(2,845 Views)
Just try what I said. 😉
(2,839 Views)
Here is a simple solution without loops or case structure.
Try it. 😄
(2,810 Views)
