array subtraction via shift registers
In the case shown there it wouldn't, especially since it is an uninitialised shift register. The data is held in the shift register unless this is the first time that loop is being entered.
But that doesn't even matter, the outputs are only read when the loop terminates so you would get the first picture from the tunnel and the comparison image from the shift register.
Message 11 of 13
(640 Views)
Oh, thanks for that clarification.
Message 12 of 13
(635 Views)
Another possibility, as I mentioned.  Using a producer/consumer design pattern, grab two images and build a 3D array with it.  Pass to the consumer loop, do the math, and display or write to file.
aputman
Message 13 of 13
(633 Views)
