array subset using condition
Hi camr,
as long as you only show the FP we will not be able to spot the problems in your BD…
Doh!
Message 11 of 15
(2,095 Views)
@GerdW wrote:
Hi camr,
Doh!
i cannot attach the program so here is the image. i just focus on what i need which is the subset array
i am not a programmer and quite lost with labview terminologies
 so please be patient with me
i encircled here where the splitting of subset array doesnt work
Message 12 of 15
(2,079 Views)
Something like this?
Message 13 of 15
(2,053 Views)
Are the X values always guaranteed to be sorted?
In any case, you could use two conditional output tunnels in the little FOR loop (where the condition depends in the scalar x comparison inside the loop) to form the two desired 2D arrays. No splitting needed later.
Even works if the x-array is not sorted.
Message 14 of 15
(2,032 Views)
Other way with 2D array (similar to Crossrulz approach):
Munna
Message 15 of 15
(1,988 Views)
