If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
array stop work when i use reinit to default
Hi guys,
i'm using a array to save data from my DAQ.. and it saves when some seconds elapsed..
the problem is.. when a i use the invoke node "reinit default" of array after it the array gets empty (ok) but dont get more data (problem)..
please help me!
thanks
(2,808 Views)
how about adding data flow so your not write to the array and reiniting the array all at the same time. connect your error bundle wires will help control the flow.
richjoh
(2,805 Views)
(2,796 Views)
thank very much ! i'll try the hints!
(2,775 Views)
