12-05-2011 05:45 AM
Any examples of creating a table from an array of clusters?? There is an example for going from a table to array of clusters.
Thanks.
Solved! Go to Solution.
12-05-2011 06:24 AM - edited 12-05-2011 06:25 AM
Hi Mark,
thoat would be a straight-forward way to convert an array of clusters into a 2D-array of strings (aka "table"):
http://forums.ni.com/ni/attachments/ni/170/620569/1/check.png
12-05-2011 06:58 AM
Maybe I should have explained more. My understanding was you used a cluster when you want to bundle elements of different types...ie strings,booleans, numeric. I'm trying to create a pass/fail report to display to the operator at the end of the test. I tried to follow your example but you can't create an array of diffrent elements.
Here is what I have:
12-05-2011 07:34 AM
Mark,
The table control wont take different types of data. Your best bet is to convert everything in to string.
Hope this helps.
regards,
aCe
12-05-2011 08:31 AM
That was the piece of the puzzle I needed.
Thanks everyone.
