array comparision
hi all
i have 2 arrays .... i simply need to check if both are same ... if same give me a true and if not a false...
by using the '=' function i get an array of true/false......... what i need is simple just a single true if they are equal and if not a false
any suggestions
regards
(2,736 Views)
Accepted by nolsqn
Right click on the equals, go to Comparison Mode, then select compare aggregates.
Message Edited by Ravens Fan on 02-16-2010 12:36 AM
(2,730 Views)
hi,
Its just extension of your logic,
see the attached example.
edit : sorry i did'nt see the above msg, it is optimised answer.
Shrek
Message Edited by shrekt on 02-16-2010 11:09 AM
(2,728 Views)
