arduino plotting
Hello all,
I'm using graph to plot continous data receiving from arduino. My problem is the graph plots continously, but what I want is the the graph should plot fro particular value of X axis i.e If I set X axis value as 50 then 50 data points has to be plotteed on graph then again 50 starting from zero value of x axis. Pls help.
thanks in advance
(3,136 Views)
Hi reva,
Two notes:
- please attach your VI: are you using a chart, a waveform graph or a XY graph?
- sometimes you have to (actually) program the behaviour you want...
(3,119 Views)
