applying delay in formula node in labview
hi every bod
Message 1 of 18
(9,340 Views)
Why would you want one? (i dont think that's possible, you'll have to split the formula and set a delay in between)
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 18
(9,326 Views)
Message 3 of 18
(9,322 Views)
And i who thought my post was the solution ... (you can untag posts if needed)
/Y
Qestit Systems
Message 4 of 18
(9,311 Views)
I think tagging is correct: the solution is that there is no solution!! Smiley Very Happy
Paolo
Message 5 of 18
(9,303 Views)
Hello to0raj:
I'd really like to help you with this issue!  Could you please describe exactly what you want to accomplish and possibly the application of this project?  Can you please tell me what version of LabVIEW you are using and what operating system you are running?  Has anyone of the previous comments solved your issue?  Thank you very much!
Greg S.
Sincerely,
Greg S.
Message 6 of 18
(9,275 Views)
hi greg actua
Message 7 of 18
(9,237 Views)
Message 8 of 18
(9,235 Views)
Hi Greg
actually I described it twice
but I don't know why in has not been published in the forum
I wanted to make a Boolean object one second on and then one second off
firstly I decided to use the formula node
its pretty easier than other applications in labview
but when I tried to use the delay as I learned in micro controllers: "delay_ms(1000); "
it didn't work
and then I posted this question
but the description of my request has not been publishes and only the title came on
finally I used two for loops one inside another one
I just started to learn labview and I don't know all items here
but thanks for reply
Message 9 of 18
(9,223 Views)
Accepted by topic author to0raj
If you have not done so yet, please go through the free on-line tutorials about LabVIEW.
Rarely is the formula node the most appropriate way to write code in LV.  The native LV constructs may be a bit awkward at first for someone with a text-based programming background.  Once you learn to use dataflow and to recognize the functions by their icons, you may find that graphical programming can be both powerful and easy to read.
For delays use the Wait(ms) function found in the Timing palette.  If you need a delay in the middle of a calculation (which seems unlikely), you may need to split the calculation into two parts and put the Wait (ms) between the parts.  See the image below for one way to do this without any formula nodes.
Lynn
Message 10 of 18
(9,217 Views)
