application builder, advanced call executable, LV70
Hi all !
I am using Labview 7.0 application builder to build my application. In that one, one option is there to call one more executable after installing this application.(Installer settings/Advanced/Run after installation).
1)
Can i call "*.bat" file  ? (seem like it's not working, i try but nothing happens, no error no nothing)
If i can't  call "bat" file i try (allready) to make "Great.bat" file (and then make that to exe with labview and then call that exe) but then comes next problem.
2)
when i use "System Exec.vi" (and first command line is "command.com /C md C:\123456789123") so i try make
folder "C:\123456789123" BUT there comes only a folder "C:\12345678" ???????? , it's lool like LV70 only uses a
8 characters ??.
How i can void this problem ?
3)
And if i use command "command.com /C Great.Bat", still same problem, i need to make folder more than 8 chr and
with space chr !
4)
Is there LabView 7.1 any new features conserning this ?
Can any one help me (even middle of summer holiday time) ?
-HeVi-
(2,667 Views)
Hi -HeVi-,
you should use the native command interpreter cmd.com instead of the DOS compatibility interpreter command.com (which seems to be  tied to 8.3 file name format).
About 1): I never tried to execute a batch file directly, but I think that you may use cmd itself as the executable and   /c great.bat   or whatever else needed as arguments.
Paolo
Paolo
(2,657 Views)
Okay !
Thanks a lot Paolo
(BTW it's insted of cmd.com --> cmd.exe)
Now *.bat file working right and i think running bat file goes like you say
Have a nice summer time ! (here north is very hot weather, allmost +25 celsius degrees)
-HeVi-
(2,650 Views)
