append waveform array
Hi everybody,
I have a task with three channels. I read from the task in countinous reading and I read a waveform array. I want to append the three waverform for each loop iteration so I can plot the whole time histories outside the loop. I used the waveform append VI, but unfortunately it doens't work since it accepts only 1D array.In the attachment you can find my VI.
(5,025 Views)
Put the waveform append VI in a for loop.  Put the input signal in a shift register and auto index the waveform array.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(5,015 Views)
I am passing wave through queue to other loop for FFT. But resolution of given wave is not good so I want to append that wave multiple times. I attached the screenshot.
(3,708 Views)
