append to a path
I can get to my VI's current path, but need to access a directory below the current path.
For example, the location of my VI might be:
D:\my program files
But I need to access a folder below that:
D:\my program filese\supporting files
How do I access the next directory down?
(3,219 Views)
Append to the name using build a path.
You can also go to the advanced file functions, list the directories under your current one, then select from that list
(3,219 Views)
Adding to what gbush said;
First strip path to get rid of the VI name.
Then build path to get to the folder.
Ben
(3,219 Views)
