append table to report: different column width
Is there a way to set different column width when using the Append Table to Report VI? as I understand, the width is distributed evently for the Append Table to Report VI.
I have a table with 5 colunms and want  to set the width for each column differently for the report printout.
thanks for your helps
H. Pham
(4,243 Views)
The funtionality exist for creating tables with different widths but it is not exposed in the existing Append Table to Report VI. You will need to create a copy of it and modify the code. Down inside it there is a property for setting the column width that is by default set to the same value for each column. You will need to provide a way for getting different column widths into it for each column.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,237 Views)
Accepted by topic author TEmember
Digging into the Append Table to Report VI by following the Column Width input, you will find Append Table to Report >> Append Text Table to Report VI >> tables.vi >>  Set Table Column Width VI. You will find an Invoke Node named SetColumnWidth. Just enter the column number and the respective width for each column.
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
(4,209 Views)
Just a warning -- I don't think this solution is possible any longer with new versions of LabVIEW (at least the way it is written above). The vis listed above have been moved into a class and made private. After searching through the forums and trying to copy-then-modify the Standard instances of the hierarchy listed in the previous response, I almost succeeded in breaking the Report class in my installation of LabVIEW. Luckily I was able to quit without saving the changes to the Report library.
Check this thread for more detail; looks like this now requires some advanced object-oriented programming.
(3,528 Views)
Yet another capability that LVOOP has destroyed...
Mike...
LabVIEW Champion
(3,521 Views)
